SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Fri Aug 15, 2003 4:42 am
Heavy Throttle's website, which is in the left hand column, has an "install FAQ", with a list of basic Q & A. There is a "what is needed?" section. Write it down, and memorize this list.
"Top Engine Harness ECU engine harness ECU Lower Engine / transmission harness Power Steering pump Power Steering high pressure Line Power Steering reservoir if SOHC car, DOHC has correct reservoir Alternator - can use some DOHC KA Alternators Starter AC compressor Ignitor Chip and assembly Wastegate solenoid controller Turbo inlet pipe Turbo outlet pipe Canister Engine mounts MAFS - SOHC can be wired to work Turbo Wastegate actuator Cam Angle Sensor Throttle Body Turbo exhaust outlet extension Bell housing bolts
Sometimes engines that are missing things like the ECU or with a cut harness are offered at a discount from Heavy Throttle or other vendors. Be aware that some parts are easier to find than others. Currently main engine harnesses are difficult to find. ECU, MAF, CAS, Ignitor Chip - these things are relatively easy to find."
Email the guys at HT with any questions. They are able to respond quickly.
