1990 240SX Starting Problem
Noone
Car: 1990 240SX
The car is stock and was driving perfectly up until the other day. After driving the car, I went and parked it and the next time I tried to crank it, the car didn't start. The battery is new and power doesn't seem to be a problem. While trying to crank the car, there's no sound.
Any suggestions as to what might be the problem? Any help would be appreciated.
dkdeleon68
Car: 1991 240
So you meen when you turn the key nothing happens, not even a click?explain a little more please.
Noone
Car: 1990 240SX
It makes no sound, not even a clicking noise. First time it has done this.
Rb240Coupe
Car: 1990 Nissan 240sx
My 240 does the same thing. It cranks but it just wont turn over. I put a new dizzy cap, spark plugs, starter checked fuses and still nothing
Bongpain
Car: 92 240sx
Noone wrote:It makes no sound, not even a clicking noise. First time it has done this.
check your starter. have someone turn it over while you hit the starter with a hammer. if it start get a new starter. if it don't start. start by getting a new starter.
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
check your starter relay first.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
Rb240Coupe
Check ur fuel pump make sure that its feedn ur car properly. Give it a lil knock with a hammer
