RamonetB »
https://forums.nicoclub.com/ramonetb-u29232.html
Mon Nov 26, 2007 6:01 pm
Hmmm....
You might want to check this:
If I understand your post correctly, you get no lights on anything? not even on the illumination of the hot and cold strips? And when you press the buttons, the motor along the driver's side doesn't move the visible linkage to change vent placement?
It sounds like something more serious than what I'm suggesting, but my climate control was the victim of many bad solder joints. So many, that my lights to indicate which button was pressed were intermittent and didn't work half the time. It's possible your unit itself is particularly bad.
You can remove the unit and open it up looking for bad solder joints. They'll be milky in color or dark brown and corroded looking. With a solder gun and some fresh solder, go back over them. This fixed my light problems.
Also, stupid question time: Are all the wires plugged into the climate control unit? What about the brown plug that goes to the motor on the drivers side? Is that attached?
