gnvarnadore »
https://forums.nicoclub.com/gnvarnadore-u53576.html
Mon Sep 14, 2009 12:45 am
A 90 model comes with the KA24E(SOHC) so if you want a KA24DE(DOHC) you can buy one used for fairly cheap and drop it in, also if you do that you could go ahead and get a KA24DE with a manual transmission still attached. as far as the parts you would need for a 5 speed swap well heres a run down of the list, 5 speed transmission, transmission crossmember, 5 Speed driveshaft, clutch master cyclinder, clutch slave cyclinder, clutch lines, shifter,and clutch pedal assembly. there is a write up on how to do the 5 speed swap in the tech articles. so at the top of the page go to tech pages and to 240 tech.
