1990 240sx , rough shaky idle, possible misfire
newton240sx
Car: 1990 240sx hatchback
1995 s14 SE
ive had it for about 2 weeks and its always been this way i just never really was too worried about it but it has started to get kinda annoying. when idling it goes from about 600 to a 1000 continuosly but i feel no problem while driving. ive relplaced the spark plug wires. my dad says my spark plugs look good. i was thinking about changing the rotor and messing with the distributor. if anyone has had this problem could you help me out?
unseenspeed
Car: 91 240sx hatchback
sounds like you have a vacuum leak. I would look at the AAV. I have used propane, not lit, and opened it around the intake manifold to see if the engine runs better. This procedure is not recommended if you are unfamilier with propane.
onosqv
Car: '92 240sx Vert
this common problem can be a million different things. And since you bought the car that way, it's even harder to pinpoint.
Here's something really quick and easy to try:
- car off: unplug the maf sensor- turn car on - does it idle better now?
If it does, check your maf & maf wiring.
FSM is your friend at this point (downloadable via searching here or under one of the stickies).
Other things that have fixed/helped my idle issue:- resetting tps/idle & base timing- changing distributor cap/rotor- fuel filter/checking injectors (they should be 12 ohms or so, at least dohc is)- coolant temp sensor - the one connected to the intake manifold
The 240sx vert I just picked up had misfiring issues @ idle - changed out the maf sensor & rotor/distributor cap - got rid of most of it (still a lil misfire here & there, but not nearly as bad as before).
newton240sx
1995 s14 SE
thanx alot man ill try messing with the distributor today when I get home. and ill take off the mass air flow sensor and put it back on and see if that does anything for me. again thankyou alot for your help. i didnt think anyone would ever reply haha
KG300ZXTT
Car: 95 s14 zenki 98 s14 kouki
IF the idle goes up and down that means that your IACV (idle air control valve) or AAC is trying to adjust idle. I had the same problem I replace d the IACV and the TPS (throttle position sensor).
U don't have to replace new parts just check or clean the old parts.Here is a link that tells You how to clean the IACV zerothread?id=251133
And try to unplug the TPS (the rpm should go up for a few seconds) and go down.
I fixed the problem by replacing both of the parts but i had spare parts. Let me know if this helped.
newton240sx
1995 s14 SE
i messed with the MAF and it fixed it im pretty sure. but thankyou for your help
