1990 240SX: Ran into an issue installing my crank (OEM rebuild)
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
(posted from my build thread)
Alright guys, I'm in need of some serious help...
I have been working on putting everything back together (mostly getting the crank in) and I ran into a serious issue.
I torqued in all of the mains to 30 ft/lbs (full torque is 45-52) and I was going to spin the crank just to make sure that everything was moving smoothly. Note: I have not installed the pistons yet - just the crank. When I went to spin the crank it would not rotate. Now when I took everything apart the crank would spin smoothly with the old bearings in it and everything. However, now it would not spin anywhere close to "freely" - I had to put over 100 ft/lbs to get it to move.
So, please help me out. I ordered what I thought were standard main bearings from Advance Auto - I told them standard and the part number on the box indicates that it isn't oversized.
For reference the part is Sealed Power MFG# 7285M
It seems like the only reason the crank would resist this much would be if the bearings were oversized.
Any help with this issue is greatly appreciated!
Arrow
1998 Pathfinder
Does anybody know if Nissan would put in 0.50mm UNDERSIZED bearings in from the factory?
I ask because I just measured the bearing diameter (installed and tightened) and compared it to the crank journal diameter and had the following measurements:
Main Bearing = 59.62 mmCrank Journal = 60.1 mm
Going by this in order to get a clearance of .020mm - .046mm (factory spec) I would have to purchase .50mm undersized (or thinner than standard) bearings. That is if in fact I received the properly sized bearings in the first place - which I am unable to find out anyway of telling besides the packaging which has no indication of being oversized or under (and I ordered standard)
