numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Wed Nov 11, 2009 5:05 am
the stock motor will do 300 if executed correctly. a dual cam swap will yield the same results with a little less torque. any swap will reach that power goal. just about any entry level suspension companies offer products that will suit you just fine as a novice drifter. the jury is still out on some of them, but that's mostly due to people raving certain products and bashing others without any real evidence on the quality/capabilities. rummage through here, the engine specific forums, the suspension forums, and the drifting forums. everything you need to know, and some crap you don't need to know, is here in nico. good luck with your project.
