Arrow »
https://forums.nicoclub.com/arrow-u15687.html
Tue Jan 25, 2005 1:06 pm
well, if you can locate that the noise is coming from the front of the engine and (I might be wrong) the top to middle of the engine... that would be a more definate possibility of the chain... another thing that you could do is to see if there are any small pieces of plastic in your oil pan... they may or may not come out in an oil change.... and to get the oil pan off you have to at least lift the engine, if not remove it :-/
But, I would say that if the noise can be limited to the front of the engine and it's not any of the accessories (ie you've done the stethoscope thing to locate the noise) then it'd be a good bet that your chain is going and will soon cause a lot of damage to your engine... and you might want to get someone else's opinion that looks at it in person that knows more about cars than you (either a friend or a mechanic)
