wa-chiss »
https://forums.nicoclub.com/wa-chiss-u37545.html
Wed Mar 28, 2007 10:35 am
ok. You might be linking two different problems together. Don't worry I did/do it too. I had the same thing happen to me but on both #3&4 cylinders. Check the compression in cyl 4. I did a comp test on 3 & 4 on my car and got 0 psi. I took the valve cover off and found my cam in 2 peices. The car would start, run rough, almost die, not rev good, backfire, etc. I too could pull out the wires and nothing would change in the way it ran. I don't think it's fuel related cause it's only on cyl 4. Also check the plug in cyl 4. It might be fouled.
