Purchased this car a few days ago for 100 bucks since it was on it's way to a salvage yard. I knew the car would not run, but i've since checked everything i can think of and i need some help. I appologize if this is in the wrong section, but i did make an educated guess at putting it in here.
Things i've checked
pulled out 9 quarts of milky brown, fuel smelling sludge and added in 4 qts fresh 10w30. This oil leads me to believe that the cylinders are completely washed down and fairly dry leading to the lower compression numbers belowspark - looks like good spark.Fuel pressure - spikes to 47psi at Key On then settles to 42 after a few seconds. according to mac tools fuel pressure testing kit.noid - have noid at #2 cylinder, didnt' bother checking the other 3compression - dry compression suspected complete cylinder washdown as follows... 1: 124 2: 120 3: 127 4: 120 according to mac tools digital compression tester
Now one thing i've noticed, i get no check engine light with KOEO like i should which says either the bulb is burnt out or the ECU is down, but i'm getting a noid signal, so i'm guessing it's not a bad ECU. I've got a battery charger on it so i know i've got good voltage and amperage, it's spinning quite fast with the starter and at this point, i don't really know where to go next.
If anybody has any thoughts on what else to check, or any common problems with a no start of this nature, please chime in. I'm at my whits end. I don't regret my purchase, but i'm realy getting frustrated!!!
