CaelanSeth »
https://forums.nicoclub.com/caelanseth-u103862.html
Mon Jul 06, 2009 9:34 am
curious as to if you have found a solution... My idle was a steady 700... I then changed my belts, cleaned my throttle body, and now my idle is all over the place, usually hovering around 2000 rpm, but after it gets hot it bounces around rapidly from 1200 to 2000. I have cleaned my IAVC, disconnected AIV, pinched my air regulator hose, sprayed vacuum lines to look for leaks, ran w/o MAF sensor, all had no effect on the idle...
