1990 240SX IRS "Fix"
NiTeRiDeR
Car: Z32 + D21 + 2x R32
Heysome guy told me about this supposed "fix" for the wheel hop that I experience.
Quote »The problem is because of your IRS(independant rear suspension), if you look under the back, there should be a v shaped frame on each side, and each point of this v connects to something with a rubber bushing, so go to home depot, buy a bunch of washers, cut off whatever you need to (cut them into C's and you will not have to drop the suspension, just loosen it) and jam them between the bushings and frame untill there is no movement. [/quote]
now personally I dont think this is a GOOD idea... but what is your guys' opinion?
