KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Tue Jan 10, 2006 3:18 pm
I have been on here trying to figure out my idle problem before. After I did some more research and tried more things, I have come back with beter details of my idleing problem. ITs a 1990 Nissan 240SX KA24E w/ A-Trans.
My car will idle at random speeds, recently it cold-started at 800rpms I believe. It will run at 550rpms in drive. During this time the car shakes badly, is running lean and there is a different sound on just one of the cylinders (cant tell which). It will go glugglugglugglugpschglugglugglugglugpsch etc.
I went into my ECU for some help, but I don't think its telling me my whole problem. The 02 Sensor is registering lean until about 2800rpms, in which it switches to normal (but still noticing the miss/detonate/backfire like sound). I got an error code 13:Air temp sensor and error code 41: coolant temp. sensor.
My car does this from cold or warm starts. It is also random. It can start fine and 5minutes into idle run like crap. It can start like crap and run fine for 2 minutes and back to crap, it just decides on its own. I don't think the coolant sensor would be causing that? My car doesnt change at all with the air temp sensor unplugged.
I have had a leaky o-ring on my 4th cylinder fuel injector, due to weather and work I haven't been able to fix this. It may just be compression related but the randomness isnt adding up.
I don't want to shell out all kinds of money on air and coolant sensors is these are just other problems, i need my idle fixed. I am tired of seeing my car sitting at the end of my driveway not being driven.
Thank you for any help possible. I would like to finally get this problem fixed, I am just too poor to go and replace anything that looks faulty and hope one day I do the right part.
