1990 240SX High Beam
DeltaZulu
Car: Basement Musician
Low beam is OK but when I turn to high beam, right head light (passenger side) turns off. Can anybody tell me the possible causes?
This has been a problem since I bought this car used. There are signs of front end corrision (and possibly both front fenders) and I corrected some damamged head light cables (around front part only). Cable, head lights, and fuses are ok. What else should I check? Wiring diagram of FSM does not help me much.
Thank you in advance.
NISTECH
try pulling back on your switch and see if the flash to pass feature illuminates the high beam. if so I would say your problem lies in the contacts in your switch.
