1990 240sx HID
jamesonw23
Car: 1990 240sx SE
Hey can anyone tell me what bulbs the 1990 240sx comes stock with? I'm trying to convert to a purple colored HID headlight and I need to know what kind of bulb to order. Thanks
vanquish2
Car: 92 240sx
aziankingz
Car: 1990 240SX SE
H4 and if your stock headlights were like mine youre going to need to buy the h4 headlamps too
jamesonw23
Car: 1990 240sx SE
K, do you know what the 6054 is? I'm just trying to figure out. Thank you.
Warped161
Car: 90 s13 the never ending project
6054 are sealed beams, our cars came with the older style units where you changed the entire light. lens and all you can get different conversion kits on ebay so that you can use more modern bulbs like the h4
jamesonw23
Car: 1990 240sx SE
What do you type in on ebay to find the conversion kits?
Warped161
i didn't get that setup, my ebay kit was like 40 bucks, bright as hell to.Left side old lens->Right side new lensThey even had a spot for an led bulb in the bottom of the lens, sorta dopey but hey
smocan
The correct way to do it is retrofit REAL projectors into the housings. However this is costly and requires some work. There are some write ups floating around for pop-up lights.
The crap on ebay are bright, but blind everyone. They aren't a true HID kit with cutoff.
97240SE
Car: 1997 Nissan 240sx SE
but they sure help out those dark roads
