NYIntensity »
https://forums.nicoclub.com/nyintensity-u100124.html
Fri Apr 16, 2010 5:28 pm
Okay, so periods and punctuation go a LONG way. Every time you type a sentence, say it in your head. If you have to take a breath, then it's time to use a comma or a period.
Aside from being a d!ck, let's try to figure this out. What do you hear when you turn the key - does the starter turn? Have you gotten your battery checked? Moving on. So you've refilled the tank. When you turn the key to 'on' (before turning your ignition to 'start'), can you hear the fuel pump prime? If so, work your way into the engine, and disconnect the fuel line right before the rail. Put a can or something on the end of the hose, and turn the key to 'on' again. If fuel comes pouring out, either 1) fuel isn't an issue, or 2) your issue is in your fuel rail/injectors. Let's assume it's number 1, or at least keep troubleshooting. If all is well with fuel, then it comes to ignition. One spark plug at a time, take it out, plug it into the wire, and then ground the plug against the body of the car. Turn your ignition on. If you see spark, that plug is good. Plug it back in, and move on to the next plug. Rinse, repeat for all 4. If your plugs check out (not a bad time to check your gap, but you said you just replaced that), let's keep moving. Are you sure you have the timing correct? The firing order is 1342, 1 being the front piston. The distribution cap is 1-2, then below that 3-4 (not numbered clockwise). How's your ignition relay (should be on the passenger side panel, next to/behind the battery)? Just a few first thoughts. You said you replaced (almost) all the ignition components in the engine. Have you checked your ignition coil? (The ignition coil is the pack that the center connector on your distribution cap connects to). A effed up distribution coil would keep you from starting too, but checking the plugs like I said earlier ought to tell you where to look. If you just replaced the plugs, wires, cap, and rotor, working your way back, the ignition coil is next.
If you've got a multimeter, it would make your life a TON easier to diagnose electrical gremlins.
