I actually feel like he was talking about throwing an RB25 turbo on actually. But I would actually think a disco potato GT28RS would be a better choice. You can probably pick them up for a decent price and if I am not mistaken the RB25 stock turbo has a ceramic compressor wheel, no? I think with a GT28RS a set of 550cc injectors and an FMIC with a decent tune that would be a really fun car for not much money.Mitec wrote: ↑Thu Feb 22, 2018 3:36 pmIf you only want 250 whp, I don't see the point in spending the $$$ to put in an RB25. Put a FMIC, larger turbo (heck, throw an RB25 turbo on) and some used GT-R 480cc injectors and you can get that out of the RB20 without having to buy a custom driveshaft and mounts.
its a built RB20 with RB25 Turbo that has HKS Turbine and Wastegate, 79mm pistons Cometic metal headgasket, eagle rods, all ARP hard ware. going sleeper with it
Very nice, just be mindful that that turbo won't handle much above 10psi with that ceramic wheel. You had mentioned a power goal of 250 whp so I think you will be alright but just something to keep in the back of your mind.its a built RB20 with RB25 Turbo that has HKS Turbine and Wastegate, 79mm pistons Cometic metal headgasket, eagle rods, all ARP hard ware. going sleeper with it
thoight that was only an issue with the rb20 turboflartius wrote: ↑Thu Mar 22, 2018 4:21 amVery nice, just be mindful that that turbo won't handle much above 10psi with that ceramic wheel. You had mentioned a power goal of 250 whp so I think you will be alright but just something to keep in the back of your mind.its a built RB20 with RB25 Turbo that has HKS Turbine and Wastegate, 79mm pistons Cometic metal headgasket, eagle rods, all ARP hard ware. going sleeper with it
HKS makes an upgrade kit for the rb25 turbo
You running 14 pounds on stock injectors? I'm not calling you out or anything I'm genuinely curious if you're having a fuel cut issue.
FWIW, I'm running 12lbs on my stock RB25 turbo. Duty cycle is only seeing 85% at full boost. I would think his injectors would support 14lbs without issues. Granted there's a 100cc difference between the two, but I would still think that he wouldn't max them out quite yet.
7mgte injectors direct swaps?
I have no idea man, I don't even know why they're in my RB20 to be honest. It came with them, I didn't even notice until I was in there installing my FPR and saw light green. I'd just go with 440's 550's or whatever, they'll be tested and offer more head room for HP. Make sure you have ECU or SAFC though so you can tune for the increase in flow.
Only looking for 250-300whp which 300cc injectors should be more than enough but if it is cheaper to go with 440s i willTreyE wrote: ↑Thu Apr 12, 2018 6:33 pmI have no idea man, I don't even know why they're in my RB20 to be honest. It came with them, I didn't even notice until I was in there installing my FPR and saw light green. I'd just go with 440's 550's or whatever, they'll be tested and offer more head room for HP. Make sure you have ECU or SAFC though so you can tune for the increase in flow.
