1990 240sx Gauge probelms
Turbo240sr
I have a 1990 240 and my factory gauge cluster wont light up. The digital clock which is under the spedo and tach is illumintated when the actual lights are off. BUt when i switch the headlights on the clock isnt illumintated and i have no gauge lights at all. Any ideas???
240sxluv
Car: 1989 Nissan 240sx fastback
It might be a short in the switch so check the switch and behind the gauge cluster and sometimes messing with wires works.
streetracer
Car: 240sx hatch
Just get your self a little light to put on your dash that sets in front of your cluster and use a switch to turn it on or off.I did that with my 93 hatchback. I spent about 250 bucks to have some one tell me that I have a broken ground wire between the computer and the gauge cluster.
ricebike
2002 Quest
2005 Altima
do your ac controls doesn't light up as well?
if it doesn't, i'd look into the white plastic box that's hidden behind the driver side kick panel... the time control unit had a blown point on the board & i soldered it together.
hopefully, it's that & not streetracer's; alot cheaper too!
e_c
Car: 1990 240sx
i also have the same problem in my '90.. .but it happened when i installed my new cd deck... i just put a light on me steering collum (sp?) and a toggle switch in the blank little button thing where the rear window wiper thing is... i looked at the fuses and all were in good shape... too lazy to search for anything else
spider_slayer
Car: S14 240SX
S13 240SX
the problem with putting a light in there is that if the fuse for the dash lights is blown i'm willing to bet that your taillights don't work eathier because they use the same fuse......so i'd be sure to check that out then use the little light thing idea
e_c
Car: 1990 240sx
spider_slayer wrote:the problem with putting a light in there is that if the fuse for the dash lights is blown i'm willing to bet that your taillights don't work eathier because they use the same fuse......so i'd be sure to check that out then use the little light thing idea
my tails still work... but i have heard that before, thats also how i knew the fuse was still good, and the prob was something else
ricebike
2002 Quest
2005 Altima
zerofile/4869/tcu.jpg
this is the TCM... that white box i was talking about... check this out since all it requires is removal--opening the case--looking for the burnt area.
other than that, grounds/loose wires...
or just be lazy & do the dash light thing; i was lazy & put it off for almost a year, but my ghetto riggin was the shizzle; little NICOtot would say, "bling-bling"
zerothread?id=21358
