1990 240sx : engine swap and transmission questions!
bigdawg182
I have a 1990 240sx (factory KA24E) and the motor/5 spd transmission (KA24DE)from a 1992. Also the ECU and harness from the 92. I want to use the new motor, but stay with the auto transmission. Will the old transmission work on the new motor, and do i still need to swap the gauge cluster/ECU from the 92 into my 1990?
Thanks in advance guys!
NISTECH
You will need the auto trans control unit for the 92 ECU you plan on using. They "talk" alot when driving. This is required for proper shifting and such. There may also be harnesses required for them to mate up.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
You'll also need a 91 or new tach as the 90 tach will not work with the 92 ECU.
bigdawg182
Awesome, ok, so what is that control unit, where is it located, what does it look like? Thanks again.
And rogoman, thanks for incite, i do have that already too, wasn't sure if i'd need it or not.
NISTECH
it is in the kick panel near the ECM
bigdawg182
Cool. Will the one from the 90 not work since it was a factory automatic?
bigdawg182
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The 90 transmission control unit will not work with the 92 ECU because the pin-outs on the 92 ECU are different from the 90 ECU.
