Alfador »
https://forums.nicoclub.com/alfador-u28926.html
Sun Jan 15, 2006 1:00 am
I took my car in for a MA state inspection in august, it failed for NOx on the emissions. (the car was relatively new for me at the time). So I dug around in the engine bay and found out that a bunch of the vac. system hoses had been bypassed (specifically the ones to the canister), so I got new hoses, checked the rest for leaks, and fixed that all up. come about 45 days later I had it inspected again (I go to college about 3 hrs from home and am usually seperated from either the car or the resources to work on it). The second inspection failed for NOx as well. I have the exact figures here...HC - 0.57CO - 8.99N0x - 3.63 (the limit for this was 3.0)I finally caved in and had a diagnostic done, and here's what they gave me for a report...
Quote »Tested emission and EVAP system. Hooked pressure up to EGR system. Found that EGR valve was working but solenoid to the valve was not. Recommend new solenoid and recheck system for inspection. [/quote]Not that all seems right, but the problem is they want $207 for parts and labor. Its the second part of this that really irks me though...Quote »Because engine has had several modifications it would be difficult to say if this repair will pass emissions level requirements and fix the problem.[/quote]This confuses me because its the original KA24E and the only modifications to it at all are an injen intake, and I was told by the previous owner that the EGR valve itself was replaced with a new OEM one about a year and a half ago because the old one was sticking.
I guess my real questions are 1. Does that all sound right? The modification comment makes me wonder...2. Is that price anywheres near normal?3. Would it be worth it to order the part and do the work myself?
Thanks in advance
EDIT: the only other mods are an exaust (all after the cat. cat itself and all parts between it and engine are original) and some body/suspension stuff.
Also, when I before I replaced the vaccum tubes and for a week or so after it Idled and started rough, but has smoothed out recently.
Modified by Alfador at 10:35 AM 4/2/2006
