1990 240SX, DE swap, rough idle - EGR?
90de4u
Car: 1990 240SX fastback, DE engine
I bought a 1990 240SX with the DE swap not too long ago and there is one problem with it. When I go to start it in the morning, it will die so I have to give it gas for about 15 seconds or so, so the choke will catch and then it will idle roughly around 1,000rpm.
Also, when I am driving and then push in the clutch, the idle is erratic...it will be as low as 800 sometimes. Usually stays right around 1,000 though. When I am slowing down in neutral, it will be as high as 1,500 - 2,000 and stay like that until I hit the gas a bit and then it knocks it back down to 1,000rpm.
I was told when I bought it that the EGR valve needed to be replaced...I am not sure if that would cause the car to do this or what. It drives just fine...has a lot of torque, acceleration is spot on. Doesn't have any ignition misses. I am wondering if the valve is just stuck open or what the deal is? It does have a CEL but nobody has an OBD1 scanner to read the code.
Mods done to the car:
KA24DE swapCone filter adapted to the stock intake tube and MAF sensor2.5" exhaust with resonator onlyStage 2 Exedy clutch
