RamonetB »
https://forums.nicoclub.com/ramonetb-u29232.html
Mon Aug 07, 2006 2:40 am
My apologies on your discontentment, but it wasn't until this past weekend that the issue has finally been resolved.
First, the brief:The thermal switch that turns the condensor fan on is located in a metal connecting pipe (the switch itself screws in to this piece) which is fitted between your radiator and the radiator hose on the LOWER side, that is the lower radiator house, or the one towards the ground that leads to the thermostat.
Replacing it can be an easy or moderate task. You MIGHT be able to get to it from the passanger side front tire. It's right there, if you were to look at it. But if it's screwed in tightly, I don't think you'll get enough torque to get it out. Otherwise, the fan shroud has to come out and you can get to it from above. I had to remove the piece that it screws into to finally unscrew the switch, putting a rathcet through the pipe to offer enough leverage to the wrench working the switch.
BTW, best to drain your radiator fluid when doing this else it's going to gush out.
Some specifications:The thermoswitch is supposed to come on when it senses a temperature of roughly 204 degrees. Types vary widely in the sense that some turn on at 198 and others at 208. I removed mine and tested it using a digital meat thermometer (you know, the kind you stick in meat to see the internal temperature) a pot of hot water, and a multimeter. Set the multimeter for continuity and test the two prongs on the plug of the thermoswitch.
YOU SHOULD GET NOTHING. An open circuit, in other words. With the thermometer reading the temperature, bring it up to about 200 to 204 degrees. Hold the switch so that it rests IN the water (NOT on the bottom of the pan) for about 15 seconds to make sure it heats up. See if you have continuity now. If not, raise the temperature. If the switch fails to come on by 208 degrees, the switch is faulty and needs to be replaced. This part can be bought from Advance Auto for roughly $20.
As I said earlier, my switch WORKED. So I was still confused as to why my condensor fan wasn't turning on. that's when I had a stroke of luck.
The termperature here in PA soared to 95 degrees this past week. That's when I noticed my car overheated (after I put the OLD thermostat back in. I agree with others on this forum, don't skimp on the thermostat. Get a Nissan or Nismo part). It simply couldn't stay cool. Driving for 20 minutes and she'd start to get seriously hot. Forget the AC, it'd heat up even faster. With the heater on, I could control the heat of the car somewhat, but she was still running hot. Thus, I inspected the radiator hoses.
The top radiator hose was scorcing hot!! I couldn't touch it for more than a second or two. The bottom one though... I could touch that for more than 10 seconds before getting uncomfortable. Obviously, my condensor fan would NEVER come on if the temperature in the coolant of the lower radiator hose never got hot enough to turn it on!! Scorching top radiator hose, relatively cool lower hose? I had a perfect superior cooling radiator!!!
NOT. Obviously, with the car overheating, this meant my radiator was clogged. And sure enough, after turning the car off, there were areas of higher temperatures on the radiator when I touch it with my hand. That and the crap I keep seeing on my radiator cap.
A new radiator and new cap later, my car runs very cool and the AC works better than ever (although, still intermittent at times, but that's for another day) and my condensor fan run perfectly now!
As a side note, when I put my thermoswitch back in, I change it's orientation somewhat. Originally it was putting straight up. When I put it back together, it is now more at a 45 degree angle, towards its side. I did this on a whim in case I had some air in my system and it was getting stuck around the switch. I've properly bled the system now, so whether or not it helped, I don't know. But the car works so I'm happy.
I hope that helps you out!
As for my AC woes, I think I'm just going to take it to an AC specialist and have the system evacuated, tested, and recharged. I'm tired of banging my head on that one. Of course... it could still be the crappy wiring job the previous owner did with his alarm system... I still have to rip all that out.
Peace!
