any idea how much resistance should be there??NISTECH wrote:The solonoid is on the side of the intake down near the bottom and more forward of center of the intake. The connector is a bit of a pita to get off but once you do use an ohm meter to test the solonoid across the 2 terminals.
could my egr valve be leaking, because when i cleaned it out, it didnt hold carb clean in the body of the valve it leaked into the exhaust side of the egr, this could explain why at lower rpms my car has a stumble in it??NISTECH wrote:about 40 ohms
Ok, i havent checked the solonoid yet, but i was wondering just for a idea on this, how does the egr valve acually turn on the cel light, acually i should say what stops it from turning it on, if i could bypass that it would be great, because i would just get egr blockoff plates and say the hell with it?? any ideas i wish i had a manual to use the wiring diagram that way i wouldnt have to ask as muchNISTECH wrote:Depending on how much open it is yes. They dont always sit completely tight and a Very small gap will be neglagable to engine idle.
can i just put a resistor like they said 100k ohm in between the two wires going to the temp sensor?? no one has acually said if this works or notNISTECH wrote:It throws the code if it doesnt "see" the solonoid in the circuit, if it doesnt see a voltage drop when it activates the circuit, if you have an egr temp sensor it also will throw a code if it doesnt see a voltage drop on that circuit when the egr is suppose to be flowing.
