1990 240sx: catalytic converter install q
TDS
Car: 2008 G35
ok this is kind of a dumb question but is there a correct way to install a cat? I bought a carsound high flow and on one side the flange is adjustable with 3'' and the other side is a solid 2.5'' flange. i have a 2.5 headers and catback exhaust. So does it matter wich way it should go? Should i stick to 2.5in gaskets or get 3in gasket for the adjustable flange? Thanks.
Should be 2.5" on both ends, if you have a 2.5" header flange and a 2.5" catback flange...
TDS
Car: 2008 G35
thats the prob. one side of the cat is 3in. Seems that side should be the outlet for 3in catback exhaust. But if i replace that flange with a 2.5 the cat can be installed either side? Is there a specific inlet and outlet to a cat?
Unless there's an arrow on the cat marked "flow", then it's universal fit.
Might want to see if you can swap it out for one with two 2.5" flanges.
TDS
Car: 2008 G35
ok thanks for the help.
