1990 240SX burned O2 Wire
Manny
Car: 1990 240SX
This is the wire going to the ECU, do I have to run a new wire all the way to ECU? can I just replace the burned part of the wire? just a regular wire will do?Thanks in advance for your help!
180fan
Car: 89 fastback
The O2 sensor wire is shielded. You should use shielded wire. If you want, you can redo the whole thing, you can just solder a new section in, use a solder high in silver and very low if any of tin.
navysnail
you think solder will hold at that temp if it burned through the wire?
s13sr20chris
180fan wrote:high in silver and very low if any of tin.
hmmm, never heard that. why is it? i usually use 40/60 rosin core but i would love to hear about silver solder. i heard that was for plumbing or something.
navysnail
you cant use lead solder to solder pipes for carying drinking water. tin and antimony 95%/5% respectivly is what i usually use, but for electrical work i use 60/40
180fan
Car: 89 fastback
locally I can find solder for my electronics that made of silver. I've used it on my o2 sensor's before the ones that are cut and crimp without any problems or degredation in signal quality. I've yet to have an o2 sensor wire burn on me though. Do you still have your heat shields on by any chance?
