dferraro »
https://forums.nicoclub.com/dferraro-u129514.html
Wed Apr 01, 2009 1:31 am
To All: Just an update... Last night I disconnected the hose from the air filter case that connects to the resonator. I covered the open end of the hose with a foam filter from a lawn mower. This morning, the car seemed to have no power under 30 mph. It seemed to take forever to get above 30. Once over 30, the car seemed normal. I will provide another update tomorrow after I see how it performs on the way home tonight. I've had the idle problem described in the tutorial but only on the way home when the outside temp was warmer then 40 degs or so. The tach would usually oscillate bet 100 & 1500rpm when I was sitting at a light. If it was a long light, the car would stall; but it would start right up. If it is ok tonight, I will try to take the AIV apart over the weekend to clean it. Thanks
