1990 240sx 17" (5 lug) offsets?
turboICE
Car: 1989 240SX race ka.
My plans are as follows:
5 lug conversion17"X7" front wheels with 205/45 tires17"X7.5" rear wheels with 235/40 tires
This will be for auto-x, track, driving usage - but eventually converted to at a minimum a comp licensing car.
My question is which offsets will fit these wheels and tires under the car well. Not looking for the "magic" number but kinda a range of 2-3 offset that will work.
Can I pretty much count on any 17" wheels that are listed on TireRack for say a '95 SE to be the right fit?
With these proposed sizes would there be any limitations on coil-over selection?
For the future when more power may be in store I would also be interested in similar comparisons of:
18X8 with 225/45 (front)18X9 with 255/40 (rear)
Nismo_Freak
Car: 89 Nissan 240SX
+20 front+30 rear
Future setup:+30 front+30 rear
turboICE
Thanx NF.
Any coil over limitations there? And will wider fenders be needed to tuck under the current or future aspirations?
edit ps: nm on the last ? I see from your posts that the offsets are likely targetted to flush fitment. I guess now my only concern is coil over limitations.
Nismo_Freak
Tein Flex fit fine with the above fitments.
Exar-Kun
Car: 2005 350Z
30 offset and 8" wheels on a s13 may scrub the front. a 20-25mm offset would be more ideal in the front...-chet
