Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Sun Oct 28, 2007 6:26 pm
Hello, I need a ignition switch for my 90 S-13 and everywhere I go they want to sell me the complete Key Assembly with the switch. I just need the switch. Can I buy that by itself or do I need to spend over $150 for the complete key and switch together. I have been to Napa, Car Quest, Hate to say (Auto Zone, Advanced Auto) and even the dealer. I live in New Orleans and most of the people working ar these stores do not even know what a 240 is. I have changed my starter, batt wires, blue ignition relay by the battery. It will start 50% of the time and then other times I get a click and if I keep turning the key back and forth it will start. I had a mechinic look at the switch and he said it has to be the problem and it felt very loose when the key was turned well he had a screw driver and was checking it against some chart. We even took voltage measurements at the starter wire and when it starts it gets 10-12 volts and when it makes the clicking noise and does not start it is only at 5-7 volts. At any time I can take a wire from the battery + and touch it to the selonide and it will always start so I know that is good & it is not getting the proper voltage at times and that is when I have to keep turning the key on & off fast for it to catch. It has to be the switch he said. Sorry so long but I just need to know if someone has bought just the switch and where.THANKS SO MUCH
