NISMO24096 wrote:ps hope its something as simple as just the slave and master cylinders thats wrong with your car and not like mine which i seem to have blew one or more of the springs out of the clutch disk. apperantly it has lodged itself in the pressure plate causeing it not to release the clutch. keep us informed of your progress...
Ok well I tried bleeding them again, at both bleeder points, no success. I had to fill the reservoir a few times, and the pedal still doesnt have any resistance or does it want to come back up from the floor on its own. I took off the slave cylinder/operating cylinder and there is no pressure against the push rod, therefore there is nothing to come in contact with the fork? I am stumped, I also hand "pumped"/ pushed the push rod a few times and sent brake/clutch fluid back up through the lines and seeping out of the master cylinder reservoir, all over under the hood, before I could figure out what a mess I was causing....
:oface ...So I am still perplexed, any more suggestions would be greatly appreciated....
