1990 240 big clutch problem
N_E_R_V_EVA01
Car: Toyota MR2, girlfriends car Nissan 240sx
first i want to say thanks in advance for helping me out. in the last 3-4 months of driving this car i noticed that the trans stated to make noise vibrate a little bit and it started to progress to a stronger vibration and louder noise . I decided to change out the clutch and when removing the trans i noticed their was alot of shaft play on the trans and decided to get a new/used trans. got the trans installed with new clutch pressure plate throw out bearing and the fly wheel was sanded and cleaned, did not see the need to resurface the flywheel. well anyways once installed i started driving the car and noticed their was alot of vibration coming from the trans. i could feel the vibration when in neutral and in all gears. it felt like the whole assemble was off balance and was shaking itself to death. on the way back home i lost the clutch and had to get it towed. pretty much the clutch was ripped apart. well my question is what would cause this to happen and what do i need to replace to get it fixed. ------> http://i572.photobucket.com/al...5.jpg <---- link of broken clutch
Cone Junky
Car: S13 fastback
BMW e46 328i
My first intinct is the flywheel. Since the flywheel was the only thing that stayed when you did the swap and it is direct contact with the clutch disc.It's also probably the reason why the input shaft on the old transmission was shot.Either replace it or at least have a machine shop check on it's balance.
s13_chris
Car: 90 240sx Hatch
Pilot bearing was also replaced?? And then do what Cone Junky says, take the flywheel to a shop.
s13_chris
Car: 90 240sx Hatch
Is the clutch disc even worn? s***ty picture- can't tell. Make sure you installed everything correctly. Make sure clutch was aligned. I don't know what else.
N_E_R_V_EVA01
the clutch was brand new, the pilot bearing was not change. is there anything else that could of caused the clutch to just be ripped apart like that? any other ideas ive already spent alot of money and dont want to put more in if it wont fix it.
Barnav1t
Car: 1992 Nissan 240SX
Having the balance checked on your flywheel should be next to nothing...Not to touch on a sore subject, but it probably would have been even cheaper to do before you put the transmission back together. Was the clutch alligned right? I've never seen that before. What did the throw out look like? Is there wear on it. The pilot bearing is like ten bucks...
N_E_R_V_EVA01
i know your right i should of done it right the first time around but money was tight and now im stuck with a broken car. the only thing i thought was also the fly wheel and the pilot bearing. i guess ill just have to save some money. any other ideas. o yeah the throw out bearing was fine
Armstec_S13
Car: S13 Coupe
you didnt mention the type of clutch, what was it?
N_E_R_V_EVA01
it was a factory nissan clutch
