I want to add a Magnefine filter this week. I have looked at all the Technical Service Bulletins I have and found two posts by Maxnix that contradict each other, No offence.
magnefine-transmission-and-power-steeri ... on%20linesmaxnix wrote:A better investment, especially for urban driving, might be the Z32 PS fluid heat exchanger.
Passenger side is the ATF return.
transmission-lines-which-goes-where-t307564.h ... on%20linesmaxnix wrote:Passenger side is supply and driver's side is return.
I believe the ATF flows top to bottom in the tanks, but will have to check.
I was thinking about removing the fuel pump fuse and cranking it over a couple of times to remove all the fuel from the fuel lines to prevent the engine from starting. Then I would remove the A/T Cooler lines and make sure all the fluid is drained out. Then I would add bags in the lines. Then I would crank it over for a few seconds and see which zip lock bag is full of fluid.
Any definite answer would be appreciated!
