Post by SFBayQ45 » https://forums.nicoclub.com/sfbayq45-u9053.html Mon Sep 19, 2005 6:19 am
Post by nchopp » https://forums.nicoclub.com/nchopp-u29406.html Mon Sep 19, 2005 10:32 am
Post by silverQ » https://forums.nicoclub.com/silverq-u33571.html Sat Oct 22, 2005 4:08 pm
Post by Q451990 » https://forums.nicoclub.com/q451990-u142.html Sat Oct 22, 2005 4:49 pm
Climate controller problem is common... a rebuild from Jerry Tucker is $100+ shipping. http://www.jerrytucker.netsilverQ wrote:You know my status display works fine in my 91Q but it says brakes need replaced and transmission malfunction .. but my climate display is blank (but works) but the thing im most curious about early in the morning sometimes my gauge cluster has like this grey indiglo material that lites up like sweet but then it won't do it again for like a few days? I'm kinda curious what that little push button by my shifter does cause the labels worn off .. anyone know? l8r
Post by Q451990 » https://forums.nicoclub.com/q451990-u142.html Sat Oct 22, 2005 4:51 pm
There are two bulbs there for backlighting. It's not uncommon for them to be intermittant in my experience. If the display failed, it should still glow, but not show numbers. If you can shine a flashlight on it (or see half of it) and see numbers - it's probably the bulbs.SFBayQ45 wrote:I called Joe and was about to order the 7 bulbs required for the message display unit, however I've been informed that the bulbs might not be the problem. The symptom originates from having the message display (on the left hand side vs. right for 1994-1996 models) sometimes displaying the full mileage numbers (i.e. 244 miles) but sometimes either go completely out or only displays the begining numbers (i.e. 24...). Would anyone have a suggestion on how to fix this minor but annoying problem?
Post by goody90q45 » https://forums.nicoclub.com/goody90q45-u31761.html Sat Oct 22, 2005 5:49 pm
Post by SpartanAir » https://forums.nicoclub.com/spartanair-u59789.html Thu Oct 22, 2009 6:44 am
Post by goody90q45 » https://forums.nicoclub.com/goody90q45-u31761.html Thu Oct 22, 2009 8:29 am
Post by SpartanAir » https://forums.nicoclub.com/spartanair-u59789.html Thu Oct 22, 2009 8:56 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
