199? 240sx automatic transmission
dccse3k
Okay, so i bought a used transmission from a guy and I need some help with a hole.
Someone stole my old one i had laying out in my yard so i have nothing to compare it to. It is a hole next to where the driveshaft slips in the transmission and it is on the left side i believe. I can see the gears from it and its about the size of a quarter.
My 240 had electronic speedometer but i think this hole might be for a speedometer cable. Does anyone know if that is what it is and then I should just be able to plug the hole w/ something?
jetroy240
Car: S13, AE86
That is where the speed sensor is bolted on w/ 6 mm bolt
