1989 with 93 DE motor: code 21 - no ignition signal
3blackbirds
Car: Silver EVO IX , 99 Jeep Cherokee Sport
My ecu is throwing code 21 - no ignition signal. I tried replacing the coil but no luck. How do I fix this?
180fan
Car: 89 fastback
is there any juice going to the ignition coil?
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Hopefully you're using a KA24DE ECU instead of the original ECU.
3blackbirds
The coil clicks, no spark to the plugs when grounded out to the body. I was showing a code 11-camshaft postion sensor, which is in the distributor. I think it's in the distrib. maybe in the wire harness. Once in a while the motor will catch for a second, then nothing. I'll keep on the started after that for a few seconds, but just a spining motor.
Yes, it's a DE ecu retuned by JWT for a 11.7:1 CR motor, ported and polished head, PDM cams.
