1989 with 1995 ob2 swap cant find the info needed.
neukin
Car: 89 240sx
1989 with 1995 ka24de ob2 swap
Well it was a auto so i have all that manual bs outa the way kinda. But i have a few odd questions that i thought maybe you guys could answer.
The sohc harness and auto ecu would work on the obd2 dohc engine if i what...? do i need to rewire the distributor and what else? If that ecu and harness wont work what do i need.
I have a chopped obd2 harness and ecu but i dont think thats a easy way to go... im not sure the non ecu harness with go into the accecery plug for the dash and such. lmk what you guys know as there is too much chopped up info on the thread i did find
THANKS!!!!!!
neukin
Car: 89 240sx
i have the engine waiting to be put in, lmk guys i really need your help with this one. Unless you guys can supply a 1989 auto engine wire diagram to the ecu and a 1995 obd2 5speed engine wire diagam to ecu i have no idea what needs done.
neukin
Car: 89 240sx
anyone have or know where to get all the wire diagrams for a 1989 240sx and a obd2 240sx?
i have the whole harness and ecu for the obd2 ka24de so now i just have to get the plugs to match up with the dash plugs and the fusebox area plugs but i have no idea whats what etc so i can get going!! lmk anything
im not sure anyone has done a obd2 into a 89 but i need some help so if you know someone lmk
