1989 S13 Hydro E Brake Rear Caliper Choices
rabrisco
Car: 1998 240sx Zenki Ka24de
Hey guys, about to install a different hydro into our clubs project car. Will be going with an ASD 16 inch pullback, dual calipers, stainless steel braided lines (not hard lines), and running a separate system from the normal brakes. Hydro will have its own separate reservoir. Anyways, we are wondering what would be the best choice for rear calipers to be able to lock up the rears? Currently it has 205/35/18. We very much would like to stay with these wheels. Would we be able to fit the z32 FRONT 30mm Calipers onto the REAR of our s13 if we use the z32 rotor in the swap? I just don't know if the stock z32 rear 2 piston calipers will really lock them up. I want to do this job once and get it right. Please let me know if you think it will be overkill, won't fit, or if someone has done this in the past. Thank you!
rapghsi
Car: 240sx
silverminemotors might help you out with your 240sx brake upgrade http://www.silverminemotors.com/nissan/ ... -brake-kit
