1989 Pulsar NX Door Handle Assembly Question
cford1080
Car: 2007 Sentra SE-R Spec V
Can anyone tell me what this part is called? It is part of the door handle assembly. The hole in the center fits around one of the metal rods leading from the door handle. To help clarify the picture, it is basically a square with a tab on each of the four sides.
I'm trying to find a replacement. This part on my friend's car is missing 3 of the tabs, and another friend rotated it so that the last tab would be where it needed to be to let the driver door open, but it doesn't always work. So I'm looking for a replacement. If anyone has one, or knows where I can find one, please let me know.
Thanks in advance!
***UPDATE***
I found out the part is called a door handle (or door lock) rentainer clip (or retention clip).
I still can't find one. It might have to be ordered as part of an entire door handle assembly. I'mm still looking. If anyone can point me in the right direction, I would GREATLY appreciate it.
Thanks again!
-Craig Ford
Q451990
I have no idea if it's available from the factory anymore, but I would check by calling www.everythingnissan.com
Heath
