1989 nissan maxima starts only with starting fluid
ljlewis7398
Car: 1989 nissan maxima se,starts only with starting fliud
My 89 maxima se 6 speed, starts only with starting fluid running until I shut it off, but it wont start without the starting fluid.
Reason: Revise Title
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
PapaSmurf2k3 wrote:
Fri Sep 14, 2018 8:21 am
Sounds like your injectors aren't firing or you've got a bad fuel pressure regulator. Have you verified fuel pressure? Can you pull the fuel rail and see if they are spraying fuel while you crank?
