Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat May 11, 2013 4:58 pm
Have you tested the fuel/vapor return lines? If it's pinched, the injector will direct all pressure into the TB.
If you've tested that already, then I would look at the fuel pressure regulator first before looking to adjust things. At any rate, the first thing I would look at is your fuel pressure. Both of those sort of failures can cause higher than usual pressure.
The other possibility is that you simply have a large air leak somewhere after the MAFs. That could be responsible for extra fuel and for a computer error that would cause it to go into limp mode, aka 3500 rpms or so.
What, may I ask, are you certified for under ASE?
