1989 nissan 240sx 2.4L
Lyles240sx
Car: nissan 240 sx 2.4L
My car has started to blow smoke and i know it would be my rings but is thare any way to help slow the burn without taking apart the engine. 240sx 2.4L
naladude911
Car: 2001 Infiniti QX4
go to the 240sx forum. Welcome to NICO though. Sounds like your going to need an essssssssrrrrrrrrrrrr swap
hsckris
Car: 07 V8 4runner
I think there are a number of threads on this.
My brother's 240 did this and it was the valve seals.
Lyles240sx
And i just changed my fule filter to and it got worse.
Lyles240sx
Sory to bug you agen but what is the esr swap. Thanks
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
It's the SR20det 2.0L turbo. Save your money for a redtop or blacktop sr20.It's the only way to go, imo.
180weaver
Car: 90 240sx
not sure why changing the fuel filter would make it worse, but what color is the smoke. I could be burning oil or coolant, they would be from different areas. you can look at your dipstick and if it looks milky it is a coolant issue, most likely at the head gasket. If its oil, then most likely your valve seals, in either case it sounds like the head needs to be removed.
Lyles240sx
So i checked and it,s not the head. And the smoke is a light blue and i have bean saving for a sr20 but it will take me a bit longer not much work out hear. Thank you fore your info. It,s nice asking questons and not having to take the car into dealers for a dio.
