1989 240sx - Won't Go Into Reverse
Screwart
So I took my car on the highway a few months back and after the trip I found I couldn't shift my car into reverse.
By this I mean you can't force it in anyway into gear. Not with the engine on or off, clutch or no clutch; It will not go into gear. The knob just stops and won't budge.
I've asked around alot but can't seem to figure out the problem. I don't think it's the transmission because all the other gears work fine. Could it be shift linkage? Bad shifter bearings?
I have no idea what to look for. Any help would be super.
carmo
Car: 92 Accord, 90 Civic, 89 240sx
I suspect you need a transmission. The shift linkage is all internal. You could try taking the shifter out and see what you find, but almost every time I've come across a car that won't go into reverse, a transmission was needed.
