Deadrodent »
https://forums.nicoclub.com/deadrodent-u29119.html
Sat May 12, 2007 12:35 pm
Hey everyone, I was taking my 240 for a little late saturday night cruise when things went horribly wrong. I had previously installed an autometer boost gauge and wired it to the car's ignition wire. I took off the gauge because it wasn't sealing properly and was causing a vaccuum leak but i kept the gauge's light wired up. I had wrapped the gauge light around the steering column so it wouldn't be hanging anywhere or get caught on anything. While i was driving the gauge light was bothering my vision so i grabbed it with my hand and attempted to point it in a different direction. Upon doing this sparks flew from the gauge light (where the wires connect to it) and puffs of smoke came from somewhere near the steering column (i'm assuming where i soldered it)
the car immediately died but the lights and everything else work. When i slowed to a stop i tried cranking the car but there was no response. The starter didn't crank, my fans didn't come on...it's like the ignition switch was busted. I had an extra one laying one and replaced it...same problems....
this is the information i have so far:
1. Does not crank, does not prime fuel pump, accessories does not work
2. fuses in engine bay fuse box all conduct
3. headlights and interior lights work
so i know i'm pretty much not getting power to the ecu and i'm not able to turn it to accessories to roll up the windows or turn on the radio or my fans....but the battery is charged....
