spec-u-later »
https://forums.nicoclub.com/spec-u-later-u7110.html
Tue May 30, 2006 7:41 pm
An alignment tool to put in a transmission? I think your talking about using it for the clutch and pressure plate. The transmission can be difficult to put in. Rotate it so the starter hump is pointing down, then once the shaft is in you can rotate it back. It helps to loosen the motor mounts and jack up the front of the engine. I'm sure your hitting the trannie tunnel when you try to put it in and tilting the motor helps a bit.
