1989 240SX Transmission Issue
bradt
Car: 1989 240SX CA18DET
I was driving back from lunch yesterday and when I shifted to 4th, the pedal would not come back up all the way and I lost almost all acceleration.Now, clutch slips like crazy. It will not grab in any gear. Still shifts perfectly fine between gears, very smooth and no grinding.
Checked fluid level and it is good, no leaking. It drove perfect before this happened, so I dont know what the problem is.
bradt
Also, the motor is a CA18DET
ricebike
2002 Quest
2005 Altima
well, if you're sure it's not the hydraulic problem,
how about checking the pedal freeplay?
you'll have to pull the trans off & check the throwout bearing, fork pivot ball, etc... mebbe the clutch disc got glazed over w/ some oil leaking from a rear main seal or something??? or the pressure plate has lost some holding capacity???
bradt
Thats what I was afraid of. I was just trying to avoid having to drop the transmission.
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
Could it also be that your clutch or pressure plate is gone? I know that my transmission acted similarly when my clutch went out.
How many miles is on your clutch (or how many do you think there are)?
bradt
Unknown. As far as I know it still has the clutch that came with the motor, which had roughly 30,000 miles on it. I am replacing the clutch and I will see how it works out.
