1989 240sx stock horsepower rating?
1989240sx
Car: 1989 240sx and 1974 duster
i was wondering if someone could tell me what a stock 240sx hp rating is
180fan
Car: 89 fastback
You need to learn to read the stickies at the top pertaining to how not to make crap titles. Additionally, you need to lurk more and go through the articles that are stored on NICO or learn to hit the red button up top that says "search".
goj_cloud
ka24e specs
Bore × Stroke: 89.0 × 96.0 mm Max power: 140 hp (105 kW) @ 5600 rpm Max torque: 152 ft·lbf (206 Nm) @ 4400 rpm Valve Configuration: SOHC, 12 valves Compression ratio: 8.6:1 (9.1:1 for early 1989 240SX)
ka24de specsBore × Stroke: 89.0 × 96.0 mm Max power: 155 hp (115 kW) @ 5600 rpm Max torque: 160 ft·lbf (217 N·m) @ 4400 rpm Valve Configuration: DOHC, 16 valves Compression ratio: 8.9:1, 9.2:1, 9.5:1
thatdudety
Car: 1991 dodge stealth
about 86-89 rwhp
BMAR240SX
Car: 1993 Nissan 240S Coupe
89hp i think thats way to underated im thinking 100-110
180fan
Car: 89 fastback
goj_cloud gets the cookie. if you're looking for wheel hp, iirc it should be ballpark high 90's to low 100's.
