ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Mon Nov 27, 2006 12:46 am
um, sorry about not checking back sooner; i was taking the driver training / test for FedEx...
hmm, did you @ least download/ read any of the free Factory Service Manuals that i've got linked in my signature?
there's 3 checks for diag procedure 1 when u didn't get past step 2: the last part, the OD light indicator seems to be working, so that one's crossed-off...
you have to check the A/T control unit's power source and ground circuits...
some1 w/ a similar FSM? see page AT-47 or i'll scan it for you l8tr...
the control unit is on the pass side, probably up further into the kick panel... above the ECU/ECM... & has a 16-pin plug... along w/ a 20-pin plug next to it: u r going to use the 16-pin plug to check for power/ground sides...
key point: but it's so weird that you have this prob AFTER you did the water pump change... i say recheck everything around that area...
Quote »At 75mph its running 5,000 rpm's. Is that what it should be or is that too high?I also pressed and depressed the OD button....while driving, nothing happened. Will it hurt anything to drive it like it is now?[/quote]that's not good to be running @ 75mph 5,ooo rpms for extended times... please make sure your AT fluid is OK. & make sure the OD OFF light is not lit up/keep OD switch ON...
any ENGINE trouble codes stored on the ECU?ECM???
Quote »Someone said it could be the OD solenoid. Is there one? and if so, where would it be located?[/quote]if ya see the list of A/T trouble codes, u will c that there are 5 different solenoids in question, so you don't wanna be throwing parts @ it ( #4-7 & 10)
