1989 240sx noise when turning
5t341tH
Car: S13
hey guys i got a 1989 single cam fastbackthe problem i seem to be having is when i reverse or even drive forward and i turn the steering wheel a lot, and i switch it to drive and turn the steering wheel the other way, the car makes a ERRR sound. could it be a bushing problem? the sound is coming from the front end so im sure its from there. im sure its not powersteering because i noe wat that should sound like. what do u guys think it could be? could it be my tension rods?
i checked under the car and this bushing/rod seems worn. its right behind the front tires could this be the problem to my steering sound?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Check the fluid level on your power steering reservoir. When turning the wheels causes a sound such as you describe it means your low on power steering fluid.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
ddgsxr504 wrote:Check the fluid level on your power steering reservoir. When turning the wheels causes a sound such as you describe it means your low on power steering fluid.
word.
ricebike
2002 Quest
2005 Altima
yup;
in addition, that thing you're pointing @ is the tension control arm... bushings can be purchased to replace them/ most likely need a press to do so or a set of "drifts" and a jack...
search from there...
5t341tH
Car: S13
the sound couldnt be power steering because its not continuous. it goes away wen it happens. and i dont go lock to lock for that to happen.is tension control arms the same as tension rods?
180fan
Car: 89 fastback
tension rods. Those guys usually result in a clanging and bumping kinda sound.
Is the sound more like a creaking or is it more like a whirring? creaking would lean me more towards the tension rods while the whirring would point me to the ps pump.
5t341tH
Car: S13
yea i think its tension rods too. its kinda hard to explain how it sounds thoh. cuz i put it up on a lift and i checked under. everything is fine cept those tension rod bushings and my outter tie rods.
ricebike
2002 Quest
2005 Altima
ooh, outer tie rod ends > tension rod bushings...
esp, if there's slight wobbling while driving.
i've driven on dry rotted tension control arm bushings for the longest time ~DD~ w/ no adverse effects, but if you got shot outer tie rods, the steering-wheel feeling of wobbliness sux.
u check the ps belt as well?
5t341tH
Car: S13
the weird thing is, i was told the car would act bad wen i have worn tension rods/outter tie rods. but im driving normal and it feels fine. only thing i notice is car kinda moves to the right a bit. it could just be the alignment.and is ps belt=power steering belt?
ricebike
2002 Quest
2005 Altima
yeap... check the belt or all of them; doesn't hurt to check... other than the fluid level.
if it moves to the right a bit sometimes & not due to a "crown" on the road, then it usually starts that way...
you can prolong the outer tie rod ends a bit if you inject some grease into the torn tie rod ends w/ a needle adaptor on the greasegun...
