BlackHat »
https://forums.nicoclub.com/blackhat-u38398.html
Tue Nov 14, 2006 4:11 pm
Ok, here's the description.
Black Arrow - This is a reference, that's the Power Steering Pulley/assembly.
yellow arrow - This is the connection that comes from the bottom of the Upper Radiator hose connection to the Intake Manifold.
Red Arrow - Connection that goes to the mysterious (at least to me) black box connected to the block.
Green Arrow - This is the back of the thermostat housing. This kinda confuses me because the U shaped hose goes from the Yellow Arrow to here. Does that sound right to anyone? If my logic is right, then when the Thermostat opens it pulls coolant straight from the upper rad hose to the lower? Maybe someone can explain this to me. I'm sure that's where the U shaped hose goes, due to the size of the connections, they're slightly different than the one on the black box.
Thanks in advance and sorry for the over-anxious bump.
