mbmdwh »
https://forums.nicoclub.com/mbmdwh-u50682.html
Mon Jan 01, 2007 1:33 pm
My car idle at 500 when I start it up and is runnng rough. After it has been running for about 10 minutes to warm up, the idle slowly increases to 1000 and hold. Engine smooths out also. Idle does not go up and down. I was told my ECU may be bad. Said injector 1 was not firing. Ohm out wire to injector and it seem OK. Found ECU on Ebay and replaced it. Same problem exist. Engine heads and timing chain has been redone months ago. Spark plugs and wires changed also. HELP!! What do you think is best to check next or go back and check. Thanks.
