puerkone »
https://forums.nicoclub.com/puerkone-u104139.html
Sun Oct 19, 2008 8:54 pm
Hi guys I'm back again I just been having this problem over a month and I just can't believe my car still runs. I go to school every day with it about 20 miles every day and every time I drive I have to shift at 3000 RPM and keep the RPM under 3000 all the time. As soon as I go past 3000 RPM the car starts misfiring and dies. Then fortunately I always keep a spare of spark plugs with me and pull over replace them on the road. Then every every week I have to change them and I'm just getting tired of replacing damn spark plugs all the time because all four of them always come out melted on the electrodes. Now I use spark plug faulters where they are screwed in where the spark plugs go. The kind of save some life out of my spark plugs but is still not enough for a week. So I already replaced Distributor cap and rotor, spark plugs wires, thermostat, hoses, radiator, water pump, fuel filter, O2 Sensor, oil change 10W30, oil filter, belts, brand new coil, and did fuel injector cleaner and brand new air filter. So any more suggestions? I took it to 5 different nissan mechanics and they eventually charge me like 50 bux to say I think your spark is no good. All bs. So I been trying to look around and ask alot of people and I found out that my chamber is running too hot. Which device controls the temperature of the fuel air mixture or the chamber? thanks Oh by the way I also installed a brand new EGR and it fixed my RPM Idleing but still melts my spark plugs jusst letting you guys:redface
Modified by puerkone at 12:30 AM 10/20/2008
